Check tuner | SatelliteGuys.US
Check tuner
metfan69
4
I have a 2009 Accord,I had a Kenwood
[h=5]AVHX3500BHS installed in my car recently.I added the xm tuner to receive xm radio through my car stereo.It was installed by Best Buy.XM has not worked right since they installed it.It freezes,then says check tuner,then says no signal,then goes back to normal.Sometimes it plays ok for a while,other times its not listenable at all.If anyone can help me I would appreciate it.Best Buy replaced the original tuner they installed and even took a third look at look at it with no luck.
[/h]
