*Choice Died? | SatelliteGuys.US
*Choice Died?
clapple
350
Palm derset, Ca.
I have a *C HD DVR. This morning I set some up some recordings. Then went back to Dish. When I went back to *C, I have no picture. I rebooted the receiver (with no results). Receiver shows time and Red timer light; but no picture. Anyone have another idea? :confused:
Press and hold the power button on the front of the box for about 30 seconds and the unit will reset. May take a 3 or 4 minutes to fully power up. Check that it was not changed to a resolution that your TV does not support. Also, try using the composite or s-video or rf out to see if you have video on those outputs.
Thanks! That did reset it. I had tried to reboot like with Dish, turning the power off for 10 seconds. That did not help.
Nimiq 4 north of Philadelphia
Getting a 75e in the US / using 75e LNB?
