Coax Surge Suppressor | SatelliteGuys.US
plastic_mac
9
I just purchased a Panamax Surge Suppressor with Coax protection. Does it matter if I place the coax protection before or after the power insertor for my SW64 switch?
The Panamax "satellite coax feed, as I recall will feed through 27 volts." So, you could place the power inserter on the receiver side of the Panamax.
Also if you are going to use it with Dish Network DishPro lnbf dishes then it may not be compatible with the DishPro technology according to Dish Network although it still may work but do not know if it would cause any problems or not.
