Codes for Syntax Olevia | SatelliteGuys.US
jballa91
29
I have just purchased a 27'' LCD Syntax Olevia tv. I looked for tv remote control codes for both "syntax" and "olevia" but couldn't find any. I was hoping if anyone has an Olevia or Syntax that they can help me out or if there is anyone who knows a site to find additional tv codes.
Google search... From the Syntax FAQ:
A: Universal remote control manufacturers specify different code for the various television brands out there. Please check with the manufacturer's list for codes listed under RCA, YAMAHA, LG, or Philips televisions. Any code listed under the RCA, YAMAHA, LG, or Philips will work.
http://www.syntaxgroups.com/products/faqs.html
Yeah, mine seems to work on the first few tries on the autoscan, does volume, tv on and off (works for me!)
I beleive 001 works, but not too sure, just do the autoscan, one of the first few works for the TV!
Fine Living is available
5 cents to 9 cents ????
