bummerI enjoy watching Comet tv on WSMH 66.3 in mid-Michigan, but they still haven't fixed the aspect ratio issue that's been there since day 1. The picture is scrunched tighter than a normal 4x3 should be, with the black sides (on 4x3 stuff) I can use the aspect ratio key and set it to FULL, and then it's correct. IF there's a 16x9 commercial that comes on, that's in the perfect aspect ratio!.
coolYou can remove the (soon) off WNOL 38.3 Comet Programming is on. Yes I caught the channel after rescanning Saturday....Also remove the (soon) off WGNO 26.3 Escape it's programming is on also....
Well, that's cool!Bear in mind, Comet does have a free online stream: http://www.comettv.com/watch-live/ - for those who do not have a local affiliate or simply prefer to watch online.
I just can't understand why they don't fix it. Apparently NOBODY that works there watches their own programming.
There are black bars on both left and right side on Comet on firestick.Please,do not tell me to go display and calibrate it.Tried that,several times,already.As a experiment I tried watching Comet live on my phones and i pad.Black bars as well.I think it must therefore be the format,they are broadcasting in?Is the network feed for GetTV 16x9 or at times are there black bars on all sides?
He's not likely to tell you anything, because he hasn't posted in 7 years. This is an ancient thread...There are black bars on both left and right side on Comet on firestick.Please,do not tell me to go display and calibrate it.Tried that,several times,already.As a experiment I tried watching Comet live on my phones and i pad.Black bars as well.I think it must therefore be the format,they are broadcasting in?
Nothing worse than "stretch-o-vision". I'd much rather have the black bars, and original aspect ratioIt is normal. The content of that particular broadcast is 4:3 ratio not widescreen hence the black bars on the left and right to fill the rest of the screen. They could have filled the entire screen by chopping the top and bottom of the picture off or by stretching it out but chose to air it in it's original format.
P.S. Welcome!
Limited time offer
