compression tool question | SatelliteGuys.US
mustang65
50
Greeneville,TN
Anyone know if you can use that zenith compression tool with PPC or Snap-n-Seal connectors? I saw one at lowe's for 12.97 and wondered if it would be worth it.
I've used the zenith compression tool with ppc and snap n seal and it worked great. I'll admit zenith isn't the best compression tool. I've got a ripley cablematic now and its lots better but the zenith will work on ppc and SNS.
Thanks. I really didn't see the need in buying an expensive compression tool because i will only need it for a one time use.
compression tool
Don't get me wrong it works good but its definatelly not something I would want to use if I did sat/catv work for a living.
directv takes more away....
Here is the next Frontier!!!
