I have a 24" dell that I bought a year ago for $605. Best monitor I've ever had. It's on sale right now for $399. I believe it has a 5 year warrantee. Good luck!
Dell 24" Widescreen Flat Panel Monitor
DELL E248WFP
24-inch Widescreen Flat Panel Monitor
At a Glance
1920 x 1200 native resolution – Stunning detail and more viewable real estate without compromising desk space.
5 millisecond response time (typical) – Helps reduce ghosting and motion blur when gaming or watching movies.
1000:1 contrast ratio – Produces darker blacks for sharper images, crisp text, better color saturation and greater detail for HD entertainment.
High Definition (HD) – Supports higher definition than HD Television and comes with an integrated DVI-D with HDCP connection.
Dell TrueColor Technology – Richer, life-like imagery that has accurate color representation better tones and hues. Reds, greens and blues are deeper and more vibrant. The Dell E248WFP features a 92% color gamut. Color gamut refers to how many colors the display can accurately represent.
Panel Performance
Amazing 1920 x 1200 native resolution, blazing fast 5 ms response time (typical), and 1000:1 contrast ratio lets you view images, documents, graphics and video with extreme detail, vivid color and fluid motion.
True Experience
The Dell E248WFP features Dell TrueColor Technology for better color representation resulting in deeper, more vibrant reds, greens and blues. With a contrast ratio of 1000:1 blacks are darker and vibrant colors pop off the screen for life-like movies, photos and games.
Wide Screen, Slim Panel
Widescreen means cinema-style viewing and an improved overall multimedia experience. Widescreen provides you with more screen real estate so you can get more stuff on your screen at once while the flat panel design makes sure not to take up very much space on your desktop. Whether you are working or playing, wider and flatter truly is better.
Everything looks better in HD and the E248WFP with its 1920 x 1200 resolution delivers high definition clarity right to your desktop. The Digital Visual Interface (DVI) with HDCP, a feature required by Blu-Ray and HD-DVD players, enables playback of high definition digital video audio with no loss in detail for life-like clarity and amazing detail.
