Configuring the VIP722 | SatelliteGuys.US
ronconnolly
12
San Jose, Ca.
Is there a way to configure the VIP722 so that when I create a timer for a record operation, I can select which tuner I want it to record from, 1 or 2? TV-2 is sometimes in use by another member of the family and I don't want to interupt their viewing.
The closest way to do what you want is to disable 'record plus': menu-8-5
Now the show will record from the TV you set the timer from. You might have to delete the old timers and start fresh.
right, what chainblu said.
if you disable record plus, then whatever tv you are standing at when you tell it to record something, will be the tv that records it.
this DOES allow you to choose which tv will record which programs.
thats the best way.
Red Sox and NESN
TurboHD Bronze
