Connecting 2 lnb's to 2 receivers | Page 2 | SatelliteGuys.US
Hello Gents
Thanks for the information, I try to change sats today and the motor is not moving I don't think is set up correct, the last time i setup a ku dish with an Invacom lnb was many moons ago, I remember I had to connect 2 outputs from the LNB to a diseqc 4x1 switch the output went to the LNB connector on the motor and the receiver connector on the motor went to the receiver, I did not have any switches in between the receiver and the motor and now I do, I have the multi switch between the motor and the receiver, I look all over the internet and guides on forums and unable to find a setup like mine, so I need you help on setting this up, I would appreciate any comments.
Please let me know.
Regards,
Chewie
Yes I have purchased INverto LNBs in the past from them, they are fine to deal with, just not local (NA). I'll likely order again from them. Would be nice if one of our favourite retailers would take on Inverto products... but it's likely the European retailers are too competitive.
Motor question about degrees
Looking for a new motor. Whats the best out there?
