I don't own one as the service doesn't meet my needs. I have installed one with OTA.harshness, I'm curious... Do you have an Orby system or seen one in operation yet?
And a higher price with a contractUnless you're a RVer, I'm not convinced that this should matter.There's a place, but probably not a big market. The difference with the other MVPDs is that they offer more channels to choose from and what you do choose typically comes with higher quality picture and sound.
I've observed that setting up a DISH (or DIRECTV Phase III) three-slot dish isn't any more difficult than an Orby dish. All of the adjustments are accomplished in exactly the same way. The Slimline is perhaps the most persnickety (but it features the coolest adjustment facilities). Dishes that require skew (including the Orby dish) are designed to be preset so you don't have to worry about the "outer" slots (or the polarity with Orby). Perhaps the Orby dish is a little more forgiving on skew, but I preset it as carefully as I would a DISH or DIRECTV dish.With Orby only using a single satellite makes installing the dish so much easier.
All dishes beg for a plumb mast and the Orby mast adjusts the same as everyone else's.
My lake system has the DISH 1000 (quite a bit smaller than the 1000.2) mounted on a chunk of plywood with three 2x2 legs (a really short tripod) and it usually takes me under 5 minutes to be watching TV (no outboard meter or undoing the cable required).
The DISH 1000.2 has about the same sail area as the Orby dish that is around 5-1/2" narrower than the Slimline.
I submit that there is no advantage to the Orby dish over a DISH 1000.2 with respect to setup. The Slimline's screw adjustments may compensate for much of the additional diligence required to dial in the Ka slots.
You've characterized this as a subjective argument and that's not really what it is. Pointing a satellite dish is mostly objective.I understand your opinion. You have yours and I have mine about the Orby dish.
Dish aiming gets easier every time you do it and as you pointed out, you've been doing it for a while.Personally I found the orby system the easiest dish i have ever aimed.
Orby signal is easy to receive. Pro a leader get it with a pie pan a s lnbf lolGet on the OrbyTV mailing list or follow on face book. A few times in the past months, both the standard STB and the DVR have been half price.
Yes, you may use the 33" dish, but be sure to have a standard LO 10750 LNBF. A universal LO 9750/10600 LNBF will not work. BTW, your converted slimline dish should work as well!
Limited time offer
