Coolsat 4000 Plus | SatelliteGuys.US
Coolsat 4000 Plus
plumberguy
19
Hi I bought a coolsat 4000 plus from C/L cheap I see it has no blind scan.
Is there any filmware to make it blind scan.
Yup I blind scan with mine when I was using it. Not a bad STB for starting out with and getting to play with it while learning. Nice and cheap was the key for me when I got mine.
I don't see any blind scan all I see is manual scan, auto scan, and pid scan.
Am I missing something I don't anything for blind scan.
I thinking the 4000 Plus did not have it and they added it with the Coolsat 4000 Pro.
I might be wrong though.
auto scan is just the transponder list
are you sure there is no blind scan? I founds the old pic of my 4000 plus and it shows that
yes I am sure it has no blind scan I see in the picture where it is but it is not there.
I loaded the factory bin then I found a bin from a different site and no blind scan.
I checked the manual on this site and I see the box I have don't have the extra VCR output So this box was made before the blind scan.
No luck for me:mad:
How does your switchbox look like?
Did Abc sd @99w go?
