PopcornNMore said:Good job on the review!
You left out that they added a hex/decimal calculator.
Thanks Popcorn.
W_Tracy_Parnell said:I had previously entered all the sats that I could see here so it must done it on its own. I wondered if they had updated the list to include more birds. Is SBS6 still missing then?
timmy1376 said:AMC 9 and SBS6 were both missing.
W_Tracy_Parnell said:They need to fix that. Also, they need to rename the "Telstar" sats. The 3500 has a complete satellite list (at least I haven't noticed any omissions) so it gets points there although they need to fix the sat names too.
lsat said:UPS man was right on time.:
Blind scan is really a step up from the Ultra. Faster and it ignores the data transponders that usually gave the Ultra fits.
I believe I also saw mention that the AC3 was not working.. well I can tell you it's loud and clear here, my 6 year old is enjoying PBS kids right now on AMC3. Receiver is showing ProLogic, but I'm assuming Clifford does not carry 5 channels.
The little bit I've played around with this thing so far- it's a winner. Box was delivered with the old software, upgraded to the factory 1.30 without a hitch.
W_Tracy_Parnell said:Well, now my brain is really fried.![]()
According to the manual for my Sherwood receiver, when the red "Digital" light is on the source is Dolby Digital 5.1. Well, it is on on the PBS channels yet the others won't work. Then you go back to PBS and its on again. So I am getting AC3 on PBS only for some reason.
Isat, are you getting any AC3 besides PBS?
Not to be too picky here, but AC3 does mean Dolby Digital, they are synonymous. However...lsat said:Remember, AC3 doesn't necessarily mean Dolby Digital.
That's what I thought but I am so confused at this point that I didn't want to say anything. Don't worry about being picky, I for one need information.TuxCoder said:Not to be too picky here, but AC3 does mean Dolby Digital, they are synonymous. .
TuxCoder said:However...
Dolby Digital does not just mean 5.1 (5 "directional" channels + sub), there's also 2.0 and 1.0 (stereo and mono, respectively).
I am hearing sound on everything (regular channels too) except the stuff on G10 and Pentagon.TuxCoder said:Your S/PDIF output should also be passing regular PCM mono or stereo output when tuned to non-AC3 channels. In the case of PCM stereo output, your audio receiver will do Dolby Pro-Logic if encoded in the program's stereo audio signal..
Limited time offer
