I'm fine with buying a new streaming stick every few years and having a separate OTA DVR.
Your choice of DVR may be the determining factor in what streaming clients you get.
Doubt it.Your choice of DVR may be the determining factor in what streaming clients you get.
In the event you want an OTA DVR (often part of cord cutting plans) and choose the Recast or TiVo, you'll have to have Fire TVs (Recast) or Minis (TiVo) all around in place of or in addition to your preferred streamer (if you preferred Apple TV, NVIDIA Shield or Roku for streaming for example).Doubt it.
This speaks to the importance of considering where you're going to get your content in the choosing of your streamer. Apple TV+ in particular is rather poorly supported by apps on non-Apple gear (though they have hit the biggies). 2019 Samsung TVs, Roku and Fire TVs seem to be the extent of their third party support thus far and that's a shame on Apple's part but they've spent most of their lives looking to peddle their own products by not playing fair with other brands.If it had a better UI and there was an AppleTV+ app for it, I'd be all in.
Consider getting a Tablo, you only need one box and every TV in your house will pick it up via a App on a Roku or Fire Stick ( does not have to be a stick of course).I'm fine with buying a new streaming stick every few years and having a separate OTA DVR.
I was only recently able to establish an Apple ID without having an Apple device (I wanted to see what Apple TV+ looked like on my Roku) so the tide is changing but it is changing slowly for a company that claims they want to go forward as a service provider.
Whether you've automated it or not, switching input devices is rarely seamless.
The Playstation series has been on the trailing edge of the streaming service mainstream for a while but it may get you what you need (a YTTV app is said to be coming soon as of a reddit post yesterday).
Get a Quad ( 4 tuners) whatever size internal ( up to 3TB) or external ( up to 8TB) HD, then then the guide you can pay monthly, yearly or lifetime.
I only need a DVR on one tv. Switching inputs is not a problem, been doing that for years.In the event you want an OTA DVR (often part of cord cutting plans) and choose the Recast or TiVo, you'll have to have Fire TVs (Recast) or Minis (TiVo) all around in place of or in addition to your preferred streamer (if you preferred Apple TV, NVIDIA Shield or Roku for streaming for example).
The exception is if you have only one TV and in that case, you wouldn't need to contemplate a Mini.
What might be important is a DVR that can handle multiple antennas as it looks like I'm going to need two. But there might be a better solution.
I'm guessing that the solution for that is to try to combine the two antennas somehow. If you're only after one station, it should be fairly easy. You'll want to make sure you're all repacked before you begin the endeavor as the equipment to join antennas isn't typically configurable.What might be important is a DVR that can handle multiple antennas as it looks like I'm going to need two. But there might be a better solution.
I submit that there is a not-so-subtle distinction between something that is automated and something that is largely unintrusive (no pops, flashes, volume changes necessary). Some are willing to overlook these things while others may have their equipment damaged by them.Mine is seamless with one big exception, and that is the Samsung K950 soundbar, Samsung chose not to make switching inputs a discrete switch, instead opting to step through 'sources'.
Finding something with 2 antenna connections might be tricky. I could use the same since around here I can get NBC or CBS but not both unless I use a rotor. I opted to not get CBS as I like the CBS all-access streaming service.
Sent from my iPad using Tapatalk Pro
I'm not sure where you read or heard this. DTV uses 8VSB modulation that is quite susceptible to multipath. It is hoped that NEXTGEN TV's use of COFDM will help to address that.Digital TV has effectively eliminated out of phase reflected signals that would be added with the twin antenna system.
That's not really an oranges to oranges comparison. NTSC used considerably more VHF channels (considerably more inclined to multipath) than DTV has and much has changed in terms of engineered antenna coverage patterns.Only by the lack of it here, comparing to NTSC before.
DXers still frequently lament what they've lost and what they've lost has been largely at the hands of multipath. When you're getting two or more roughly equivalent signals that are out of phase, you're going to have problems. COFDM is supposed to address this issue but many of the same authorities reasoned that multipath wouldn't be a problem with DTV.If you have trouble with multipath, maybe your equipment is really old. I just looked it up and you are correct that 8VSB did suffer multipath when it was first introduced but in modern equipment is almost non existent except in moving TV's.
While that is true, it doesn't have to be. Mine is seamless with one big exception, and that is the Samsung K950 soundbar, Samsung chose not to make switching inputs a discrete switch, instead opting to step through 'sources'.
So instead of switching inputs to it with something like 'HDMI 1', I have to push 'source' until it gets to the one I want. Since most of the time I'm either on the Tivo or the AppleTV it isn't a big deal since they both use HDMI1. And that switching is controlled by an HDMI switch that does have discrete commands. Makes for more of a mess with wiring, but once its all wired up it doesn't matter. That's on the main viewing room.
In my bedroom it is seamless because the setup is different.
Limited time offer
