Corotor II dual on Ebay | SatelliteGuys.US
pacificrim
1,199
1,117
West Coast Canada
Looks like a good deal for anyone looking for a dual C/Ku setup
Chaparral Corotor II C/KU Band Feedhorn - C & KU LNB's & SERVO MOTOR plus extra
Ending very, very soon
Those Corotor IIs are long lived and robust. My original 1993 installation is still chugging away out in the yard. Nothing "junk" about it. I wish my newer FTA Ku stuff would hold up as well, or even half as well.
Reactions: KE4EST
I guess you really aren't any sort of SatelliteGuys Pro, if you call that "old crap". However, your posting name is certainly appropriate, good choice...
Dude I been doing C band Dishes since early 90,s I have put my fair share of C band dishes up. No way you could tell that feed horn and Corotor is less then 10 yrs. old
The new equipment uses a LNBF or a Bullseye II wide band or dual polarity with Norsat LNB’s
  • Wow
Reactions: solarvic
What difference does it make how old the corotor is? They are premium equipment. If you knew so much you wouldn,t call them junk or crap. If you think they are junk or crap it shows that you still need to learn!!! Maybe you just do not know how to set up one!!!!
Reactions: Captain Midnight
You certainly wouldn't get it cheap if you bought a Bullseye loaded with 4 Norsat products. Sounds like well over $1200 new - if you could find one.
Try like 2,500 that is the professional gear, separate LNB 's for H and V on Both C and Ku band.. So I know my C and Ku band equipment
I'm using a Chaparral orthomode feedhorn from the late 80s with new NJRC PLL LNBs. Zero issues whatsoever. Now, I wouldn't trust a 30 year old LNB, but a feedhorn is a feedhorn if it isn't damaged. Sure, my feed isn't an ADL, but my 30+ year old Chaparral is just as good as a new Chaparral. Same for the corotor horns. Slap a new polarizer motor on and it is as good as new.
Who Read This Thread (Total Members: 5)
