oregonxfile said:OK...
I've opened a can o worms o sorts....
Tell me...If I strip right down to the inner foil layer, and remove all the excess foil and braid, will that work??
I've seen picture on the net with this strip, except it was for termination with a crimp connector.
Is this totally wrong, and if so , can someone tell me the pros and cons??
Thanks...
X
Mike500 said:I know that it will work and work for a long time. This works in engineering all the time. It doesn't meand that it will work in the most extreme conditions. If stripped correctly and prepared correctly, even a standard or trishield connector could be used. It might be even better, since the hole of the retention sleeve is smaller and provides a better seal.
I prefer, however, to go the little bit extra for my high end customers.
oregonxfile said:ANOTHER question!!!
With this cable setup, running 2 cables(for now anyway) to 2 separate receivers, with no splices or splitters along the way, at what point should I be concerned about signal loss for cable runs?? Each individual run should be in the region of 75 feel or so. Also, is it ok to run the cables side by side until they separate and go to each receiver, or should I try to keep them apart if possible once they come off of their respective SW21's?? I'm going to keep them off of the floor of the crawlspace by running them through the floor joists (those combo metal/wood type)
Thanks again for your help!!!
X
ciaraco said:A wise man once said "Don't let the bastards grind you down." It seems appropriate enough...
Limited time offer
