CW600s premium won't accept WEST | SatelliteGuys.US
juancruz
3
CW600s premium won't accept WEST Direction when entering New Satellite. Any suggestions?
you have to enter them a little different. They have to be entered as East. You take what the wetern satellite is and subtract from 360
so if you want to add 74W it would be
360-74 so enter it as 286
Thanks, ICEBERG, but it won't accept a number higher than 189 either. I found that you had suggested that in another thread a year ago. No good yet.
OK...
antenna setup
edit satellite
select add and a box pops up
put in the satellite location
2nd option shows east or west
3rd option says C or KU
No WEST Yet
Iceberg,
You select W,
then you press OK......
and it enters the new satellite with an E direction!!!!!
At least there's two of us trying. I wonder, no one has tried to enter
a new sat in this machine???
Regards.
improving my signal strength
Twinhan Visionplus 1020a
