D-I-Y HDTV Antennas | SatelliteGuys.US
D-I-Y HDTV Antennas
Ive seen some lumenlab antenna posts before some look good and some look scary. If anyone really wants to make an antenna more correct and good enough for transmitting you will now need algorithm data.
I once made an ultra high gain UHF yagi out of some old aluminum rods and a long piece of wood, I was actually able to watch cable tv from the box leakage on the street. I might have to try to make another and see how far out I can dx HDTV.
Grounding
New and need help
