D11 Receiver? | Page 2 | SatelliteGuys.US
D11 Receiver?
My eyes are not what they used to be, so I can't tell you what the FCC ID on the H-10 is. However there is an FCC ID number on the back of the remote that I can read. It's MG32081 The remote for the H-10 may look like the remote used on most of the newer receivers, but it's not the same. The remote for the H-10 has an extra button on the upper left hand corner. (Format) The model number for the H-10 is RC-24 while the remote for most of the others is R-16
The remote SHOULD be the same for all the new HD receivers. I know that its not the same as the remote with SD receivers like the D10.
JimONeill said:
Anyone have more information?
Yes, I have. :p
There is a Philips D11 as well.
The D11 is *not* MPEG4 compatible. I don't know where charper got the feeling it could be.
It's a basic box with more or less the same features as the D10. (It's going to replace it).
Compared to the D10, it has a USB port added, is a tad smaller with a slighltly revamped front panel.
It shares the same remote and same User Interface (with Active) as the D10 and the R15.
DTV HDSTB Resolution Problems
DVD Recorder?
