Daylight Savings Time - is your STB 1hr behind? | Page 2 | SatelliteGuys.US
dbstv said:
Map here is miami Florida is 4560
still one hour back
Again, 4560 is the satellite map. The Off-Air map is the next line on the same screen. ;)
Ok, so far, the following DMAs reported the DST problem:
0008 Washington, DC
0015 Cleveland, OH
0017 Miami, Fl​
Anyone else?
Now, is there anyone in those DMAs not having the clock problem?
Ilya said:
You should still have an Off-Air map associated with your box. I believe this is how your STB knows which time zone you are in.
Where do I find this?
f it helps I am 60 miles N of NYC
You can check your Off-Air Map by pressing HELP-INFO-OK-Down-Down-Down.
dlm10541 said:
Thanks 0001
So, is everyone in NYC having this problem? Or is it on certain boxes only?
1080iBeVuMin said:
Time is wrong here even after reboot (still 1 hr behind).
Satellite map 4560, northern California.
1080iBeVuMin, pretty much everyone has satellite map 4560. What is your Off-Air map? ;)
OAM 0014, St. Paul Minnesota reporting and still off by one hour. Also, haven't been able to get Fox channels since last week. Missed 24. Grrrrr. Any idears why?
Jeez, you guys can complain about anything. The guide still shows the correct movie playing. Some of you should get more of a life.
VOOM has been working on fixing this problem since early morning.
Mine is correct now. Anyone still having the clock problem?
Well just now, according to my partner, the Downstairs unit is still on old time but our upstairs box is current humm. Will go check the other unit myself in a bit. It should be the same OTA map tho 0018 I think for Denver. Will try a reboot of it and see if it corrects itself.
Edit: Yep still 1hr behind even after a soft reboot. It is OTA map 0018
