Db and BER readings compared to signal quality | SatelliteGuys.US
SkySurfer80
229
149
Tennessee
Well after buying a Satlink meter It has a db and BER readout. The signal qualitt readout on it is pretty useless as it is always between 60 to 69 on all locked transponders. I never paid attention to db and ber but am learning by using this meter and have to say it is very helpful. After unwarping my 90cm and using this meter and its db and ber readouts I have totally locked in my dish to what I believe is the best quality I can get.
I am trying to figure out a conversion of signal quality to db ratio but not sure it would be accurate so I am still learning.
For instance on the newsource on 87 west I am hitting at a 89 quality and a 14.5 or so db, however on the NY lotto feed "Adtec2" I am hitting at 30 pct quality and a 10.2 db. Then on 91 News channel mux I am hitting at 81 pct quality and a 13.6 db. So I am curious how the receivers come up with quality and it seems like you just cant max out all tps to high 80s or 90s.
Any of you have any light to shed on this info about Db or BER?
SNR (Signal to Noise Ratio) is expressed in db. The higher the dB reading, the higher the signal carrier strength compared to the noise floor. A receiver will require a minimum SNR to lock. The modulation type and FEC (Forward Error Correction) ratio determines the minimum SNR reading. For example, a 16PSK or high FEC (9/10, etc.) Will require a higher level of signal vs noise to reliably lock onto the carrier.
BER (Bit Error Rate) is the percentage of bit errors received in a transmission measured over a time period. The reading is displayed as ten to a negative power. The lower the BER value reading, the less amount of error correction is required resulting in higher quality transport stream decoding.
The optimal signal reading is a high SNR dB reading and low BER reading.
the problem is that SNR is a science, but Signal Quality should be one too, with a clear equivalence to SNR reading, but instead it seems that each manufacturer, and even each receiver, has its own scale... so a SQ reading makes some sense only in comparison to other readings on the same receiver.
Otherwise we would all be using Linkbox 9000 receivers right now :-)
Reactions: SkySurfer80
The Edision OS MIO 4K displays signal quality as SNR, measured in dB...
yes and I love it!
It can be switched to %, but I much prefer it to be displayed in dB. Some skins even display in BIG fonts (when in Signal Finder) so that you can reasonably well read it while adjusting the dish, if you have the display not far from the dish. Really nice!
ABC 95w Network Feeds 4000 H 30000 Transitioned to DVBS2 HEVC 4:2:2
Best ku band lnb on the market and expected signal improvement?
