Dell remote code? | SatelliteGuys.US
Dell remote code?
you'll have to figure out who actually makes the TV. Dell's name is likely the only thing Dell has to do with it. Usually companies like Dell have TV's manufactured by someone else, to which Dell pays $ for them to package it as a Dell TV.
If you can find that out that might help you in the right direction. More or less find out what brand and model and use that code in remote and it should work. (Perhaps Philips, best guess after using google) Try some Philips codes and you might get lucky. If not keep searching.
Though there is a chance you won't be able to get it to work. Some brands that are actually on the list don't work because they are too new.
Want to get dish--need advice and a good deal
HD Movies
