Digital channel | SatelliteGuys.US
Digital channel
tictoc
7
what is a good solid digital channel that is easy to tune into? I need one to do some tunning so I can get digital running.
thanks
Mike
Do you mean DVB digital or Digicipher digital?
[edit] i see from a previous post you have a 4dtv receiver, sorry i dont have 4dtv so i cant help [/edit]
Are you talking about 4dtv digital or DVB?
If you are talking about a 4dtv, you must get the unit authorized before digital will be active, and then any digitals on Galaxy-10 or Galaxy-12 are very strong so you can peek the quality on those with bumping and skew till its at its max, and then do it for all the other birds.
If you are talking about DVB, then you can do a scan on most any bird and should find something, and then tune the quality to the highest with bumping and skew.
