Digiwave HDTV Digital Satellite Receiver (HD-9003PVR) | SatelliteGuys.US
krajchi
2
sault ste marie
[h=1]Digiwave HDTV Digital Satellite Receiver NEW (HD-9003PVR)[/h]got this to setup on a 36 inch dish and got a digiwave dgl-990d linear dual lnbf square type set everything up and it says that its not supported can you all help I don't know much about it I have the 9003pvr receiver ifs it the lnbf which one will work
[h=1][/h]
I searched for that LNBF, and it should be fine for Ku, as should a 36" dish.
Did you enter the Local Oscillator frequency (10750) into the receiver?
What frequency are you trying to receive?
Since you posted in the C band section oh the forum, are you trying to get a signal in the 3.5 to 4.0 ghz range?
Tell us what setup screen you are on when you get a "not supported" message.
have two recievers old one and a new one the old shows that it works theres a menu that shows up when I hook up the new receiver it don't show anything just not supported flashes to the screen
LNBF
[h=1]Digiwave DGL-990D Standard Linear Dual LNBF (Square Type)[/h]with [h=1]Digiwave HDTV Digital Satellite Receiver NEW (HD-9003PVR)[/h] which is new and all I get is not support on the HDTV screen could it be the lnbf not the right one!
AMC18 NASA
