Diplex FTA and a fixed output together? | Page 2 | SatelliteGuys.US
Thats what happens when the old brain starts working :)
Kinda like when Dr Hydro wanted to run a couple satellite feeds to 2 maybe 3 rooms and after 2 pages of posts we figured out how to run 5 or 6 feeds to three rooms using a 3x4 multiswitch, a 4x4 multisiwtch and Diseqc switches. :)
and then we added a OTA antenna in the mix.
Always thinking on how to optimize the setup I have :)
I really appreciate the effort you put into helping me figure that out Tony, great job :-D
Did you get it all hooked up yet or is it like mine and a "work in progress" :D
I'm in the process of moving my whole setup to the downstairs "man room" where I have ample room to set everything up and run wires through drop ceiling (where my setup is now I have holes drilled to run cables up to living room) which is a project in itself :D
Still a work in process, had to spend my "extra" cash on non fta stuff :-( On the up side, all i need now is the 4x3 switch, and i have found one fairly inexpensively. I have the diseqc switchs and the cables run, so probably will be doing it all during the evenings next week.
Manhattan Skyline 1000 Receiver
Problem with Invacom Quad
