I can not find direct burial RG-6 cable in my area, does anyone know where I can get some? along with the connectors? I have to replace the cable to my dish out in the field. thanks!
Bob Haller said:DONT USE DIRECT BURIAL!!!!!
Bury flexible conduit instead, and put regular RG6 inside it.
NEVER need to dig again and if standards ever change just add some cables.
4 inch schedule 40 PVC drain pipe is a excellent choice and cheap too. Its available in flexible form for ease of installation
chadzx11 said:If you use pipe, make sure you have some way to get additional wires through it. running a string will do no good if you install and dope a lot of 90 degree joints. Its hard to pull a string through a bunch of bends. Imagine tying a cable to that and trying to pull it.
redbeerd said:I can not find direct burial RG-6 cable in my area, does anyone know where I can get some? along with the connectors? I have to replace the cable to my dish out in the field. thanks!
Limited time offer
