Direct tv HD DVR Gennie ? | Page 2 | SatelliteGuys.US
Hutch1814 when the software download automatically where do you see it on your DVRhd34 Receiver New software in the Menu ?
There is a forum here for FIOS and other cable companies.
raoul5788
I put a thread in the forum here FIOS and I can not find it ?
click on the link posted above by iceberg for the FIOS forum. you had created a fios thread in different areas so i moved one of them to the correct forum and the rest were deleted.
I apologize I am not technical I have a new 34 Direct tv replaced today questions the guy set up DEFAULT FIRST run ONLY all episodes keep til what I do not get is First run only Example my local news is on at 11 pm new and repeat at 1 30 should it not repeat the 1 30 it dose and shows like ESPN first take and sports nation do to is their away to tell shows in first run only which should not repeat in first run only ?
royrdsjr the Direct tv guy told me shows like my local news is on at 11 pm new and repeat at 1 30 should it not repeat the 1 30 it dose and shows like ESPN first take and sports nation repeat continuesly dose it is their away to tell shows in first run only which should not repeat in first run only ?
We have already explained this to you more than once. If the information in the description doesn't show the 1:30 show as a repeat it will record both episodes.
raoul5788 you said If the information in the description doesn't show the 1:30 show as a repeat it will record both episodes. what could you I do not get this information in the description you meant on the first 11 pm news show ?
ejb1980
repeat. Press info, then select more info. Read for the first run show which records first ?
You have been told at least 15 times how to check for the repeat. Press info, then select more info. Read.
Ok ...
Tonight's 11 pm news, will have TODAY'S date in the info section ...
The replay of the 11 pm Tuesday night news will get recorded again at 1:30 am because the 1:30 am info will still have Todays info in it, mainly because theres no real reason to worry about a replay of the news.
IF by some chance you looked at the 1:30 am listing and it showed tomorrows date on it, it would NOT record a second time.
My local news repeats do not show a first air date, because it's obvious. If I set up a recording, it records both.
Press info, then select more info. if the show says New it will not repeat the second show in first run only ?
Is the Hr 44 available in Jacksonville, fl???
New Customer - HR44 in Indianapolis Market?
