DirectTV High Definition Channel Signals | SatelliteGuys.US
mlminbtr
2
United States
First, thanks in advance for any assistance on this issue. I have a DirectTV 3-LNB satellite dish and I'm in Baton Rouge, LA. I set-up the dish and got a good signal right-away, but I could not get any HD channel on the guide or any reception (with the exception of one Hispanic Channel). I really don't know where to start asking this question so I'll just start here...
Do you think it's an alignment problem (I had a good clear view of the sky and it was a beautifully, clear night) or could there be a problem with the LNB's on the dish? I was getting a pretty good signal on most of the transponders on satellite 101 and about half on satellite 110.
Again, thanks for any help.
What dish and receiver are you using? Phase 3/ Slimline 3 with multiswitch/ slimline 5 with multiswitch/ slimline 3 with SWM/slimline 5 with SWM, are you using BBCs?
Are you getting the rest of your HD channels in HD ?
If yur not getting any HD channels, are your BBCs on, remember they are not needed if the dish is a SWM set up.
Have you tried a re authorization yet ?
I'm guessing your referring to Local channels your getting from D*, not OTA, right ?
Sent from my Samsung Epic using SatelliteGuys
it sounds like you have a Phase III dish which is smaller than the slimline and has the wrong setup
If it says "multi-satellite" on it that is the Phase III. To get HD you would need a different dish
Second Season of "Call Me Fitz" Premieres on DIRECTV's Audience Network
Series Recording Issue with JAG
