so i want to know if there is a way to use three dishes instead of one. i know i need 99 101 103 satellites. can i just use a 36" dish and put a directv single lnb on it from a 18" dish? thanks
I think it's possible, but not easy. Try a search here. I seem to remember a thread about it a couple of years ago. It sounds like you have line of sight issues.so i want to know if there is a way to use three dishes instead of one. i know i need 99 101 103 satellites. can i just use a 36" dish and put a directv single lnb on it from a 18" dish? thanks
No ...so i want to know if there is a way to use three dishes instead of one. i know i need 99 101 103 satellites. can i just use a 36" dish and put a directv single lnb on it from a 18" dish? thanks
What is your goal here? Are you trying to use a bigger dish for some reason, or do you really have no location where you can pick up 99/101/103 at once but believe you have three locations where you can pick up each one individually?
im wanting to just have three dishes instead of one. thats all
Very interesting ...Its possible but you would have to buy some custom LNB stuff, diplexers and 22KHz switches.
The first DirecTV Ka signals with video were received on a prototype AU9 dish with all but one feed covered with aluminum foil and it fed a home made converter to fool the L band only input of the test receiver. BTW, the reflector on that dish was not stamped, it was machined out of a solid block of aluminum. With enough time and money you could assemble anything.
But wouldn't that dish actually be the prototype of the "AT-9" 1st generation Ka/Ku ODU?
(That is, the one with the 110/119 sidecar?)
View attachment 136815View attachment 136816
Sent from my LM-V405 using Tapatalk
I have one of those dishes that I have kept inside my building for years. I wonder if there is still a use for it since everything went slimline these days.
for filtering wouldnt PPC or Eagle Comtronics??????
Hi y'all,
Is it possible to use a 18x20 directv dish with the Dmyco D4S Pro DVB-S2 Satellite Receiver ? I would be using a Vanpho Dual Output KU Band LNB High Gain Universal Ku Band Twin Output Hd LNB Lnbf Two Output LNB.
If so what would I need to do to get it to work and receive as many channels as possible?
Thanks for having this forum, I hope this isn't a completely idioticidiotic question. Lol...
Limited time offer
