Directv instillation question? | SatelliteGuys.US
c00terj
21
I want to get directv for my home but, from my backyard I'm not sure if the dish has a clear line of sight because I live in a 3 story townhouse and can't put it in my front yard due to all the hoa bs. What I would like to know is if direct tv will get on a 3 story roof to mount the dish so that it will have a clear line of sight? thanks
Have D* come out, if they have no Line of Sight they will cancel the order.
Also, you could contact a local company that installs and they may be able to come out and check LOS for you.
Are there other townhouses nearby with dishs? You can get a good idea by looking at which way your neighbors odu's are pointing.
Dishpointer.com
Smile, they are watching you. Enter your address and you will get a sat pic of your house with lines to the Directv sats. From there you can plan where to put the dish + do what bayoubrut suggested in #4.
Joe
What Lnb do I have?
HR-21 and Dolby Digital problems
