Directv International Dish | Page 2 | SatelliteGuys.US
There are two forms of mounts for the worlddirec dish, it was finally redone a year or so ago, it currently has a mount similiar to the ka/ku or slimline dish.
Sent from my PG06100 using Tapatalk 2
It's actually the same mount now. They stopped shipping the ODU-36 kit and now just ship dishes and we use the same pole, standard mount, and "stubby" mount with them
Yes, that is definitely good to know, guys. Tnx for all the input. I just didn't want any more holes in my roof if I could help it. Tnx. E_V
We've been using them little over 2 years now but we could've been a beta market with then
so they may or may not be nationwide, well id say good luck to op, but your probably going to have 10 new holes in your roof
and Hutch, hows the 18" look on a 2" mast lol, or did they re-engineer the azel to fit it, are monopoles required on sd dishes?
Nope, 18" looks funny on then but the OP may get lucky, we have a "stubby" mount now too. It's just a normal mast without the curve on the top of the mast and only sits about 8-10" off the roof that don't require monopoles on ANY dishes. The 18" doesn't require monopoles on older 2" mast either, on KA/KU and international dishes
If I'm able to put up a "stubby" tomorrow ill get a pick of it for you. I believe somebody already put up a pic of one
ive seen it installed locally, always wondered what exactly it was, the dish looked like it was just sitting up on the roof, no polls, no nothing on it.
Yeah they're pretty sweet! Makes it easy, 6 bolts and no monopoles! Bad thing is if the roof isn't level you're in for a bad time peaking. They only move up/down and no side to side movements
I think id rather work with a standard jpipe and the two length monopoles in that case. Never really had any problems, ya just need a quality torpedo level.
PS3 Hr34 Playlist
Questions on converting to HD
