Yes, we do.
The "mmwave" frequencies sold for 5G so far (28 Ghz and 24 Ghz) are the same frequencies used for Directv's Ka band and reverse band uplinks. If they were harmful, then anyone working at the broadcast centers should be dead by now
What we do know is it probably isn't going to work as well as everyone thinks it should, at least at first.
They are not broadcasting towards the employees...they are broadcasting to space.. 5g is flooding your neighborhood with radiation at much closer distance
Sent from my SM-G950U using the SatelliteGuys app!
There is a difference between ionizing and nonionizing radiation.
But people should be aware, there may be some risk.
Emphasis on Dish doing it, but not if ATT does it?
A satellite dish is receiving a signal at around -90 dbm, which is about equal to 3 bars on your phone (there is no standard scale, so it depends on the software the phone is running exactly how many bars equals how strong of a signal) Phones can typically lock a signal up to around -115 dbm or so. Cellular signals are insanely weak, the idea they can cause health effects unless you climb a tower and hold your head against the transmitter is just ridiculous conspiracy theory level Bullsh!t.
If Dish ever puts a 5g antenna near my home or business I’m suing them for health reasons[/QUOTE
I work on 30 Ghz high power satellite equipment to get an RF safety monitor to even chirp we have to put it on a stick and get it directly into the beam between the reflector and feed. The EIRP on a 5G cell site is far weaker than that.
https://www.multichannel.com/news/pay-tv-lost-1-point-7-million-users-in-q3“AT&T, the leading pay-TV provider in the U.S., accounted for 79% of the net losses in the quarter compared to 30% of net losses in 3Q 2018. This change is largely the result of AT&T’s strategic decision to increasingly focus on retaining and acquiring more profitable subscribers.”
AT&T is reporting almost the same free cash flow from Directv that they were a few years ago when there were several million more subscribers, so they probably aren't lying about losing the least profitable customers. So far.
Yes, very true. The RF levels on the main reflector of a high power transmitting dish can be surprisingly low because they have been spread out from a very small concentrated area within the feed to the large surface area of the dish. Put the same RF monitor between the feed and sub reflector and it will go up in smoke.
Limited time offer
