DIRECTV Transponder Map ~ Data 6/18/2025 | Page 79 | SatelliteGuys.US
DirecTV Satellite Transponder Updates for Jun 18 2025
Comparison of Transponder Data for Jun 18 2025 vs Jun 11 2025:
No changes in system tables for any transponder tuning parameters.
Stream (PID) counts:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
3​
HD​
275​
1445​
SD mpeg4
140​
198​
SD mpeg2
446​
-1​
RB​
Audio​
89​
Push​
30​
Slate​
21​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
1​
SD mpeg4
1​
SD mpeg2
RB​
Engr Work​
38​
1​
The PID count Excel workbook provides much more count detail.
Newly updated tables of Streams on each transponder are available in the DataDigesters TPN Grids
More details of changes in individual channels will follow in the Weekly Analysis
and Gary Toma's Domestic TPN Map Excel files
US Open and TEST channels removed
Weekly Analysis soon
Enjoy
DataDigesters
Reactions: lordodogg
Question for KyL416: big mess coming up in Miami... what do you think DTV will do with the new ABC affiliate in Miami on August 4th when it moves to the FOX affiliate's sub-channel 7.2 ? The current ABC affiliate WPLG becomes an independent and will stay on Channel 10... so, does DTV insert the new ABC station on Channel 10 and kick WPLG out of the Guide (to keep ABC where viewers expect it) or does it create a 7-2 number for ABC in the Guide and keep Channel 10 where it is ? There is already a Channel 6 and a Channel 8 in Miami so they can't insert the new ABC on Channel 6 or 8 to avoid creating the 7-2 number. Thanks for any help with this !
WPLG has every right to keep their cable and sat carriage on channel 10.
If they have a carriage deal in place, they'll probably put WSVN-D2 on channel 5 or 9
PIP not showing ON Option
