I got an error for clase to 2 months. Cleared the cookies, and and catch....nothing worked. Then one day it was back....Has anyone else had problems with the d* website? It never works!
Yesterday I tried to access tier site and I got there, then it asks to Log in, thats wen my trouble started, it would sit and spin forever, says Redirecting, I waited 10 minutes, then left the site and moved on.You're probably talking about the "Access Denied" error that would pop up a lot for me, especially when they still had the old online guide (not the one they use today that's "shared" with Stream's guide). Kyl416 said that happened because the guide was so badly coded you would send their servers a bunch of rapid requests if you scrolled the guide too fast and thus your IP would be blocked from accessing directv.com for a few minutes.
That has nothing to do with your Genie 2 and isn't model specific as it's also happening on Hx2xs and Genie 1s. It's caused by bad Channels I Get data that began a few weeks ago after they repurposed the sports mix for one of the popup sports experiences. You can still manually enter 205 to view it or watch it via channel 600.205 still don't show up in the channels I get list
point being nothing works with dtv!!!That has nothing to do with your Genie 2 and isn't model specific as it's also happening on Hx2xs and Genie 1s. It's caused by bad Channels I Get data that began a few weeks ago after they repurposed the sports mix for one of the popup sports experiences. You can still manually enter 205 to view it or watch it via channel 600.
The website is terrible, but tier Sat service has worked very well for a long time ... at least for me.Sometimes I get a 502 bad gateway in chrome or edge. It depends on wich one it wants to act stupid in. Question is does anything work with dtv. My guess is no
My TV and Sat signal has worked Great for years.point being nothing works with dtv!!!
Hmm PQ and signal are fine. just somethings in the settings menu were missing. the server just did a reboot last night now there all back after the reboot. i'm thinking it has something to do with dtv doing software updates. though never had that happen before the icons were right there after setup.My TV and Sat signal has worked Great for years.
Limited time offer
