Disappearing Channels | SatelliteGuys.US
egrichards
6
Pearland, TX
We recently upgraded our 3ABN system from the old workhorse Manhattan receiver to a Pansat6000 so we could time shift record the stuff we wanted to watch. The receiver works great for 3ABN, Hope, Esperanza, and their associated radio channels, but we've lost LLBN a couple of weeks ago. Is anyone else having this problem?
LLBN working good here.... maybe you need to re-scan or re-align your dish.
For some reason I lost all my AMC 4 channels and I re-scanned and I got them again. 3ABN is at 11822 and after I re-scanned I got it again at 11825.
I think my LNB drifts because of the heat.
welcome :wave
LLBN is there....just saw it last night
Try a smart scan for it. It should still be there :)
(antenna options, smart scan)
I'll try again tonight when I get home. I've tried the smart scan a couple of times, and re-aligned the dish during the amc-4 center of box time.
try a manual scan...antenna setup-->>edit satellites/Tp
select AMC4
select add
enter LLBN as
12020 frequency
H polarity
2034 symbol rate
and see if it shows a signal quality. The 3ABN & Hope channel are very strong so maybe the dish just needs to be tweaked
Finally getting close to getting FTA
Building a Reversed Dish Pro band stacked LNB for a T90
