Dish 322 Audio Problems | SatelliteGuys.US
Jtrekker
3
I have two Dish Network 322s. About once a week in the morning, I turn on my TV and notice I have no audio on the receiver. I keep the receiver on overnight to record, and I use a timer to keep the receiver from calling out and going to sleep, but I am wondering if this might be part of the problem.
I anyone else experiencing this or have a solution?
This happens with both recievers. They both seem to lose audio sometime early in the morning. There is not problem with audio on stuff I record the evening before. Any ideas?
Its not a common problem, Im not sure if its due to the receiver(s) being on overnight, if they stay on 24/7 then it could be due to that if they are not being allowed to download the epg update each night and its also possible that your receiver(s) may need to download a software update. Try turning the receiver(s) off for 30 mins and then turn them back on before you head off to bed and see if the problem persists. You can also set up the receiver(s) to come on when your shows that you record start playing by way of the timers.
Superdish 121 w/0 121 lnb
any chance of getting a 2nd 942 leased?
