Which dish would be better at picking up spotbeams at zip 15845 from the 119 and 110 sat's, the dish 500 or dish 1000? thanks, pajer
He should be able to set the 1000 for 119 no skew and maximize signal seeing 119 is the center of that dish. Aim the 500 at 110 and peak that without skew then combine the signal through a DP34.hall said:If you have (2) Dish 500s, point one at 110' and one at 119'. In theory, you should be able to get 120-125 on BOTH. One dish, aimed at multiple satellites, has to trade off strength...
shodobe said:I have a tech coming out in about a week to re-peak my signals because all I am getting on the 129 is 40's to low 50's. I am thinking about calling them to tell the tech to bring a extra dish with him so I can re-point 129 to 61.5 to increase my signals. This will be the 3rd time out for them. It seems they can't get a better signal so instead of them coming out every 2 weeks it would be better to just put up a second dish. My question is, do they just move the 129 LNB to the second dish and just run the coax to it, or do they have to put in a switch? Also the channels that are on 129 I have heard they are mirrored on 61.5 so I wouldn't be losing any of them, I am in the Sac-Stockton DMA-95255. Thanks
Limited time offer
