That is what I was starting to wonder as well, if this is being caused by lnb drift. Did they have many issues with the DP twin lnb's for lnb drift?
He said the 721s were more sensitive to the drift than newer receivers.
I am not well versed on LNB drift, but it seems unlikely that every 721 owner involved in this thread developed LNB drift problems simultaneously. Of course maybe I know even less than I think and it is possible. Please correct me if I have my head up my heinie.
Just to reiterate, as I said several pages back, I am experiencing no issues whatsoever with my 721 at this point. It seems to have healed itself.
That flashing SS caused by bad sat tuner chip
Oh, now the LOF drift taken into that SS screen.
My experience with such problems in past shows:the reason was 100% of the chip ( not a card !) failure.
Actually it is nor a card, but sub PCB, because it doe not sit in a slot and cannot be re removed without desoldering. Man, I'm sound to technical, but your terminology is so 'internal' - we are live in other 'PCB' world.![]()
That flashing SS caused by bad sat tuner chip - same reason exist for 501...510 PVRs, the model share same chip and same problem. I saw reports when ppl 'borrow' the chips from 501 or other (301 ?) receivers and fix the problem in 721.
Actually it is nor a card, but sub PCB, because it does not sit in a slot and cannot be re removed without desoldering. Man, I'm sound to technical, but your terminology is so 'internal' - we are live in other 'PCB' world.![]()
Limited time offer
