dish aiming? | SatelliteGuys.US
dish aiming?
jughead
9
new to fta would like to know where to aim dish
to get the most satellites i have a dish mover that
moves 70 deg each way and at what elevation should
the dish be at I'm in new york 10573
thank's for any help
SBS6 is where you want to be pointing your dish as its your true south satellite.
But I would REMOVE the motor for now and use the angles below to find it first, after you have found and stored some channels ONLY then put the motor back on again.
When you get round to doing that post what make of motor you have HERE for more help!
Code:
                    Rye Brook, NY 10573
          Latitude 41° 0.468'N Longitude 73° 40.320'W
                       Sat Name Sat Lng Az(t) Az(m)   El  Skew
                       Amos 1/2    4.0W 103.7 118.4  6.6 -47.2
                Atlantic Bird 3    5.0W 104.4 119.1  7.3 -47.0
                Nilesat 101/102    7.0W 105.8 120.5  8.8 -46.6
     Telecom 2D/Atlantic Bird 2    8.0W 106.5 121.3  9.5 -46.3
                     Express A3   11.0W 108.7 123.5 11.8 -45.6
                     Telstar 12   15.0W 111.8 126.5 14.7 -44.5
                   Intelsat 901   18.0W 114.1 128.9 16.9 -43.5
                          NSS 7   22.0W 117.4 132.2 19.7 -42.1
                   Intelsat 905   24.5W 119.6 134.3 21.5 -41.0
                   Intelsat 907   27.5W 122.2 136.9 23.5 -39.7
                  Hispasat 1C/D   30.0W 124.5 139.2 25.2 -38.5
                   Intelsat 801   31.5W 125.9 140.7 26.2 -37.7
                   Intelsat 903   34.5W 128.8 143.6 28.1 -36.0
                    AMC 12/T 11   37.5W 131.9 146.6 30.0 -34.2
                        NSS 806   40.5W 135.1 149.8 31.8 -32.2
                      Pas 3R/6B   43.0W 137.9 152.6 33.2 -30.4
                         Pas 1R   45.0W 140.2 154.9 34.3 -28.9
                   Intelsat 705   50.0W 146.3 161.0 36.8 -24.8
                   Intelsat 707   53.0W 150.1 164.8 38.1 -22.1
                   Intelsat 805   55.5W 153.4 168.2 39.1 -19.7
                          Pas 9   58.0W 156.8 171.6 39.9 -17.3
                       Amazonas   61.0W 161.1 175.8 40.8 -14.2
                     EchoStar 3   61.5W 161.8 176.5 41.0 -13.6
                      Rainbow 1   61.5W 161.8 176.5 41.0 -13.6
               Estrela do Sul 1   63.0W 164.0 178.7 41.3 -12.0
                   Brasilsat B2   65.0W 166.9 181.7 41.8  -9.8
                   Brasilsat B1   70.0W 174.4 189.2 42.4  -4.2
                       Nahuel 1   71.8W 177.1 191.9 42.6  -2.2
                      DirecTV 1   72.5W 178.2 193.0 42.6  -1.3
                          AMC 6   72.0W 177.5 192.2 42.6  -1.9
                          SBS 6   74.0W 180.5 195.2 42.6   0.4
                     Echostar 4   77.0W 185.1 199.8 42.5   3.8
                          AMC 5   79.0W 188.1 202.8 42.3   6.1
                      Nimiq 2/3   82.0W 192.6 207.3 41.8   9.5
                          AMC-9   83.0W 194.1 208.8 41.6  10.6
                   Brasilsat B3   84.0W 195.5 210.3 41.4  11.7
                          AMC 2   85.0W 197.0 211.7 41.2  12.7
                          AMC 3   87.0W 199.9 214.6 40.7  14.8
                           IA-8   89.0W 202.7 217.4 40.1  16.9
                      Galaxy 11   91.0W 205.4 220.2 39.4  18.9
                     Nimiq 1/4i   91.0W 205.4 220.2 39.4  18.9
                   Brasilsat B4   92.0W 206.8 221.5 39.0  19.9
                      Telstar 6   93.0W 208.1 222.9 38.6  20.8
                      Galaxy 3C   95.0W 210.8 225.5 37.8  22.7
                      Telstar 5   97.0W 213.3 228.1 36.9  24.5
                      Galaxy 4R   99.0W 215.8 230.5 36.0  26.2
                     Spaceway 2   99.2W 216.0 230.8 35.9  26.4
                DirecTV 1R/4S/8  101.0W 218.2 233.0 35.0  27.8
                          AMC 4  101.0W 218.2 233.0 35.0  27.8
                     Spaceway 1  103.0W 220.6 235.3 33.9  29.4
                          AMC 1  103.0W 220.6 235.3 33.9  29.4
                         AMC 15  105.0W 222.9 237.6 32.8  30.9
                      Anik F1/R  107.3W 225.4 240.1 31.5  32.5
                      DirecTV 5  109.5W 227.7 242.5 30.2  33.9
                EchoStar 6/8/10  110.0W 228.3 243.0 29.9  34.3
                        Anik F2  111.1W 229.4 244.1 29.2  35.0
                  Solidaridad 2  113.0W 231.3 246.1 28.0  36.1
                       SatMex 5  116.8W 235.0 249.7 25.6  38.2
                     DirecTV 7s  119.0W 237.0 251.8 24.1  39.3
                     EchoStar 7  119.0W 237.0 251.8 24.1  39.3
          EchoStar 9/Telstar 13  121.0W 238.8 253.6 22.7  40.2
                     Galaxy 10R  123.0W 240.6 255.3 21.4  41.1
                      Galaxy 14  125.0W 242.3 257.0 20.0  41.9
                  Galaxy 13/H 1  127.0W 244.0 258.7 18.5  42.7
 Intelsat Americas 7/Echostar 5  129.0W 245.6 260.3 17.1  43.4
                         AMC 11  131.0W 247.2 261.9 15.7  44.1
                   Galaxy 1R/15  133.0W 248.7 263.5 14.2  44.7
                         AMC 10  135.0W 250.3 265.0 12.7  45.3
                          AMC 7  137.0W 251.8 266.5 11.3  45.8
                          AMC 8  139.0W 253.2 268.0  9.8  46.3
                   EchoStar 1/2  148.0W 259.6 274.3  3.1  47.9
       Satellite Finder is (c) Copyright 2004, P. Lutus
thank's for the help the motor i have is a sg-2100 it will be install
on a 36" dish with a qph-031
thank's for the help again you guys are the best!!!
Cool!
Remember the L.O. for L side of the QPH-031 is 10750
The L.O. for the C side would be 11250 :)
The SG2100 is a GREAT motor, had mine nearly 3 years and has NEVER missed a beat!
thank's for the info so do you think if i set up on SBS6 I'll get all
the satellites on that list?
thank's again for the help
Not all some are C-Band needing a 6' dish, and some the footprint may not be aiming in your direction, I would say you can expect to get signals from most of them :) (With elevations above 15º)
authorized by the boss - but is it worth it?
Help me put these dish sizes in order
