Dish and the RV | SatelliteGuys.US
Dish and the RV
octanefam
6
2
So I recently bought a RV (30 yr old RV) to primary use for Tailgating purposes so with that being said I want to get it hooked up with Dish. I'm already a dish customer for last 15yrs so what are my options? I don't really want to spend lots of money on this setup but want to be content with it. Since my Seahawks won the Superbowl we are lucky enough to play on Thursday night we will want to watch on the pregame stuff.
So fire away with your recommended setups.
Thanks!
temp pad mount, tripod mount or if you are handy with tools a engineered temp pad with a couple concrete blocks 4 masonry anchors and lag screws with a normal dish mast.
acquire a dish for what ever arc your home set up is and take a receiver from you home and use that, if its a non hopper system.
or spend the $400-$500 and buy a tailgater combo kit from dish which includes a 211z receiver, if you dont feel like taking the time to point and peak in dish.
Longhorn Game not in HD
Dish pointed east but showing west transponders???
