That was always my theory.I'll bet that's the real reason the Sling Extender was never released: no way to charge a monthly fee for it.
I understand the confusion, just keep in mind the Sling adapter that is available with DISH is it's own device, it is not compatible in use with any app, computer program or set top box that has a Slingbox app. Slingbox is a different device. So the WD app works with a Slingbox only. (pro HD and newer)
slingbox.......
Well... At one time I had the SlingPlayer on my XP PC playing off my Sling Adapter just fine. Probably that capability has since been broken... Anyhow, due to the unavailability of standalone players on PCs, I use my Sling Adapter maybe once or twice a year.
The latest SlingBOXes use your BROWSER for viewing on PC or laptop, etc. I know many preferred the older players for viewing on the PC, laptop. So as not to add to any confusion, the Sling mobile Apps are for mobile devices; Slingplayer for Connected Devices are for use on connected devices such as WD Live, etc. While the Sling Player APP for mobile devices are outrageously priced at a one-time $15 purchase (that's a separate $15 purchase for EACH mobile device you want to watch your Sling content), the SlingPlayers App for Connected Devices are bundled for FREE on each of the connected devices such as the WD Live and Sony, etc. Did I still manage to confuse? Sorry.
I have to say, I do like the Sling experience on my WD Live Hub. It takes some getting used to, but it is the best player I've used, comparing it to my PC and both my Android tablet and Kindle HDX. I have to say that while the PC browser experience and the Android Tablet are adequate, the Kindle HDX is difficult to use and lacks good UI and NOT easy control. There is a delay when entering commands on the WD (as is the case in all the Sling Apps I've used), but the WD provides the closest to the at home with the Dish box experience. If you are using high bandwidth, the delay in not at all a problem, but I don't know if it is worse lower bandwidths. I for one am just PLEASED to be able to view my stuff remotely at no extra charge. It is a great solution for those who need Dish in an additional room, but where the additional monthly expense of a Joey just doesn't make sense, and in really good quality if your home network is decent.
Finally, I should add that the Connected Devices such as WD allow for a DIRECT connection from the device straight to the TV and really good quality and a just like at home experience. Otherwise, you have to use the PC or laptop app and connected that to your TV (can be a pain) or in some way use your mobile device and send to to the TV via wire or RF, but also a pain. Man, the whole Sling options can be really confusing.
......I have to say, I do like the Sling experience on my WD Live Hub. It takes some getting used to, but it is the best player I've used, comparing it to my PC and both my Android tablet and Kindle HDX. I have to say that while the PC browser experience and the Android Tablet are adequate, the Kindle HDX is difficult to use and lacks good UI and NOT easy control. There is a delay when entering commands on the WD (as is the case in all the Sling Apps I've used), but the WD provides the closest to the at home with the Dish box experience. If you are using high bandwidth, the delay in not at all a problem, but I don't know if it is worse lower bandwidths. I for one am just PLEASED to be able to view my stuff remotely at no extra charge. It is a great solution for those who need Dish in an additional room, but where the additional monthly expense of a Joey just doesn't make sense, and in really good quality if your home network is decent.
Sounds like you need a MK808B or RK3188 android stick. They connect via hdmi.
Splitters/switches and extenders are a much more popular (and sure-fire) solution to in-home viewing.Soooooo, bumping this thread again . . . anyone use either of the above two devices?
Soooooo, bumping this thread again . . . anyone use either of the above two devices? We would like to feed another HDTV on our home network with Dish Anywhere - the above use the android app, right? Which of the above two are preferred and how does picture quality look? Looks like they can be had relatively cheap.
If one does not mind the clunkiness, seems like a good way to avoid the $ 7 monthly fee for yet another Joey?
Anyone have an Iview 100MD dongle. It's supposed to be able to mirrow a tablet on a tv. I picked one up for $20. Haven't gotten it to work yet.
It's pre installed. (judging from my WD player all are automatically installed) It's under live apps. Be aware if you are using a theme UI some do not have the live app catagory. You have to be using the stock theme, them make Slingplayer a favorite. Then you can use any theme and slingplayer will be under favorites by hitting the down arrow on the home screen. (Not using the category favorites)
Limited time offer
