dish azimuths and skus | SatelliteGuys.US
1000 series dishes come with an installation manual with azimuth, elevation and skew listed in a table by zip code.
For Dish 500 all you need to do is input your zipcode into the dish point screen of your receiver and the receiver tells you the info.
1000.2 to 20 receivers install
Which SAT should you have with a 722/HD
