i just bought a brand new seal hopper 3 from eBay. I just finished opening the sealed package I noticed there was no smart card in the unit do they have a built in one?
For a possible future change. It's happened in the past.Sorry for asking but why is there a slot that says smart card on the left side
6 to 10 minutes on the initial setup, about a minute on a random manual check switchHow long does it usually take for a hopper 3 to check switch?
How long is it going to take you to just relax and enjoy?How long does it usually take for a hopper 3 to check switch?
Is the covered dish pointing at a brick wall?
You probably don't need it. It has internationals, as has been posted, and a horse racing package.Ok so void the 118.
Limited time offer
