So I had the hopper 3 delivers it was to late to cancel the order. Spoke to the installer he basically told me I need the 1000.2 dish. I also need the hybrid lnb for western ( not sure which one). He also shahid I need a hybrid hud ( not sure which one). He said that way I can use both satellites the 129 in the other patio to receive the 129 which the hub is suppose to help. Then use the 1000.2 for the 110,119. I then called back to get part numbers I didn't get the proper help. I live in Canada and currently using the regular hopper. I moved for work reasons. He told me the lnb need to have a line in which will bypass the 42 switch I don't need anymore per his instructions. I would appreciate all the help and solution if one is available.
Thank you for your time.
