Also, as a word of caution to anyone out there:
If you are buying a NEW Dish NOW! setup, I would recommend to everyone out there to NEVER purchase the $40 prepaid card found at Radio Shack, or elsewhere, until it can be proven that the system works. This is because with those $40 prepaid cards, you are FORCED to use the full amount on the programming you are ordering. So if it does not work, then you are out $40, with no recourse. Radio Shack will not refund it, but ALWAYS KEEP YOUR RECEIPT for a refund on the equipment.
A better way to see if it works is to buy a Green Dot Money PAK from WalMart, or wherever(they DO sell them in Radio Shack near me as well), load it with $20, which is the minimum allowed(plus around a $4.75 service charge. Charge varies, with WalMart being lowest at $4.64, that I have seen), and then order 1 day of something like Cinema
Showtime/Cinemax/Starz have the lowest per day charge rate of $.43 cents), and then see if it works.
If it works, HOORAY!! Then order what you want at will. If it doesn't, and you have tried all avenues to get it resolved with no luck, return the equipment to Radio Shack(with receipt) for a FULL refund within 30 days.
Then call 1-800-GREENDOT for a refund on your GreenDot MoneyPak. Explain to them why you want the refund, and they will gladly do it. I have done before a few times with no problems at all. They were very helpful. They also refund you your service charge of $4.64 or more as well.
So in the end, if it does not work, you will be out .$43 cents, which is better than $140+, which you would be out with getting the full system, and the $40 prepaid card that does not work.
