All decoding is done in hardware. The CPU is nowhere near up to the task.However it makes sense that a software upgrade could allow MPEG4 to work, just like downloading a codec on your PC can allow you to play XviD and stuff...
The Logitech Revue premieres on Oct 6th, I would think everyone should get the update prior to that date. Hummmm!
One theory holds that the "box" is already integrated into the ViP922.Not the VIP 922 no new firmware in sight. This Wednesday the google box will be out and the folks who will probably order this box through dish will not be able to intergrate it their 922.
The update broke the guide on my 722. Guide is VERY slow. Takes 4 seconds to come up after pushing the button on the remote and 2-3 seconds to scroll each time a push the button...
I was just hoping they would brick them all and give us 622's as replacements.any updates on the way for vip612
I was just hoping they would brick them all and give us 622's as replacements.![]()
That probably applies to back-end changes that we can't see.Misc. Updates is my favorite
I'd like to be able to enable/disable this, just in case. The 722k has had it for a while now and no user-interface either, so don't expect or look for it on your receivers. Reason is, my old-a** rear-projection HDTV has had this option for 5+ years and it works really, really well. What I've noticed with Dish's addition is "loud" parts of TV shows or movies are now toned way down, taking away the effect.SRS Volume Leveling must be automatic and involuntary, because I cannot find an option for it...
Hmm, I guess I haven't looked lately... When they first added it, there was no UI for it, as I recall. Looks like the 722/622 doesn't get the UI either on the initial release. It will probably be added later.I don't have that option on my 722. I have it on my 722k, but not my 722 (L670.)
I rec'd it overnight (10/5).I just read on the "other" forum that L668 for the 722k was a dud and that they're no longer spooling it?
Limited time offer
