I called Dish Sunday morning to complain about the low video output of the 811 receiver and the fact that the hd/sd button did not work. They are pretty much clueless about the 811.
I was handed off to a senior tech who had to put me on hold 3 times. The result is that they are sending me a new receiver. The tech told me that if I had low video output from any of the outputs on the receiver (I am using a Dvi-Dual cable and S-Video hook-ups) that the tuner in the receiver was not functioning properly. He also said that there was a software upgrade to allow the OpenTv to work properly.
I tried to explain that there were alot of complaints about the low video output on this site, however he is sending me a new 811 anyway. He did tell me that the SD/HD button isn't needed as the receiver does the switch automatically. Thought you were supposed to be able to switch this?
BTW, an interesting side here, I have locked up the 811 using the Pro-UHF remote twice. I use my Pronto-Neo (IR only) and the 811 hasn't locked up with that yet--Hummm?
