dishonline question | SatelliteGuys.US
dishonline question
coverton
2
When using a homeplug adaptor for dishonline do you only need one hooked up at your router? By the dish diagram it seems that you use one at your router and then you just plug your reciever directly into wall outlet. Can the internet connection occur through the recievers power cord? Also the homeplug I purchased uses a USB cord to hook to computer. Is that OK?Thanks
My adapter plugs in to the router, and into the adjacent wall plug. The connection does travel thru the powerline to my 622. Nothing needed on that end.
I don't know about the USB to your computer part, though.
Tom in TX
alternative to Dish 1000[.2]?
Dishnetwork 7200 receiver
