gamefanatic said:Thank You BobaBird... Just saved me a bundle!![]()
Why did you just switch your car insurance to Geico?
Scott Greczkowski said:I also found in the box from DishStore.NET 3 Dish Pro Plus separators and a DishPro Dual LNB (I am going to convert my dish at 61.5 from Legacy to DishPro technology)
This sounded like an "official" disclaimer to me rather than a technical, "No, it won't work."Unfortunately there are guide data conflict issues that create operational problems with the receiver if this combination is used. As such, it can not be offered as an acceptable combination.
I asked if this was the issue and if in fact the DP+44 would work the same way, realizing that it was not a recommended or supported installation. Here's the response:We currently have a legacy SW-64 switch connected to 119/110/61.5 cascaded with a SW-21 switch connected to 148. We can see all 4 dbs orbital positions and we are aware of the duplicate channels in the EPG that result. We can scan "up" through the duplicates but not "down" since the receiver defaults to 61.5 on them.
The simple work-around is to use the EPG or BROWSE feature to go past the duplicate or to manually "type" in the next lower channel number we may wish to tune in.
So there you have it. It will probably work if you can put up with a few work-arounds but don't tell non-technical people to do it and don't call or email DISN Network with any issues you have. The CSRs and tech support people are just going to say it's the wrong thing to do.You will most likely experience the same behaviors. It might vary slightly, and could even vary slightly when using newer receivers. You could experiment but there are no definitive answers to your question due to this not being a supported configuration. You could also try hiding the duplicate channels using the locks feature to see if it helps.
JohnDoe#2 said:So I told him how I currently have 61.5/110/119/148 hooked up with legacy eqmt and explained how I workaround the duplicate channel issue.
BZZZZ...wrong answer, Scott.Scott Greczkowski said:So Dave Kummers back from vacation then.![]()
Did you overlook this:So what is the workaround?
JohnDoe#2 said:BZZZZ...wrong answer, Scott.
(Good guess, tho.)
Did you overlook this:![]()
(Good guess, tho.)
Lots of variables. If the total run was 10', you could get away with using a wet string.memphismafioso said:If I have a 6'-10' run of the older RG59 in the wall between my RG6 drop from the Dish to the receiver am I "SOL" with the DP44+?
jsa_sf said:After several failed attempts to use a single feed from a DPP44 switch to a 921 unit using a separator near the unit, I was informed by a CSR that the code on the 921 and 721 does not support the separator yet, and that only the 322 and 522 support it at this time.
He said it would work in the future, but not now.
I'm curious how you got yours working, Scott? v1.86 does work with the DPP44 switch, but not the separator...
-j
Limited time offer
