DMSI Android + DVB-S/S2 receivers | SatelliteGuys.US
wallyhts
Staff member
HERE TO HELP YOU!
3,219
448
Android + DVB-S2 satellite receiver
Highlights
  • CA+4 x USB+Ethernet+Wifi+BlueTooth+SD Card Reader
  • Android 4.2 Jelly Bean
  • Dual Core Cortex-A9 1.5GHz *** The manual and slides says its a quad core trying to confirm"
  • Powerful 3D Graphics processing unit
  • DLNA/Miracast/Airplay supported
  • DVB-S2 H.264 Full HDTV 1080P
  • 4 x USB for PVR and media player
  • XBMC hardware video decoding fully compliant with Full HD video
  • NesTV for multiscreen interactive on smartphone and tablet
  • Verymatrix CA supported
Features
  • Fully DVB-S/S2/MPEG-2/MPEG-4 H.264/AVC Compliant
  • Unicable and MDU LNB Supported
  • HTML5
  • Auto DiSEqC1.0 and DiSEqC1.1/1.2/USALS Supported
  • 8000 TV&Radio Channels Supported
  • NIT Auto Search,Blind Search,Manual Search,TP Search and Multi-Satellite
  • Search Supported
  • 7 Days EPG (Electronic Program Guide)
  • Easy-going Program Editors,Teletext and Subtitle Supported
  • PVR, Timeshift and Playback supported
  • Upgrading Supported by OTA,USB
  • Data exchange (Backup and Restore) with external USB storage
  • Low Power Consumption Standby
I have a unit on the way to test. Will post when I get it.
  • AndroidDVB-S2_SS6B3A.pdf
Reactions: N6BY
So Leo at dmsi run a cpu ID app for me and the results are.....
Cores- 4
Architecture- 4 x ARM Cortex-A5 @ 1.54GHz
PS: I did not see in person I will confirm when my unit arrives. :)
A few quick pics. Screen shots to follow.
So i log into the play store and try to download slingtv. However after logging in TV reboots WTF... So I reboot the STB and try again same thing Grrrr. Never seen this before. Has 2 app stores.
Using walmart black Friday Emerson.
This is crazy leave the tv on and play store comes up for about 15 secs then screen goes black.
Reactions: primestar31
What about the satellite side? How does it perform?
I had to hook up usb mouse so i cloud search play store :(
Oh...thought maybe you fixed that....not good.
When booting up an error message comes "open the app fails" right out of the box. Not sure what app. I'm going to hook up to some birds i'm crossing my fingers :)
Here is a clip of blindscan on 125. You will noticed that not many USA sats are in the list.
Also the STB is not decoding Dolby Digital so i'm not going to spend anymore time until Leo at DMSI tells me how to enable if it even can be enabled :(
Online Update. I'm really wishing I was at the office on GigE :). But hey Update Available.
I have a feeling it's downloading 449MB from China server the great firewall be slowing it down.
BOO BOO BOO BOO!!!!!
Galaxy 19 - 97W Ku-band channel guide (Aug. 8 update)
Wooden post for 120 cm Ariza dish
