Dmt1050u | SatelliteGuys.US
Dmt1050u
hunter2
18
NY
Folks, does anybody has a DMT1050U FTA receiver?
I lost my manual; I can't find the way to rescan the satellite. I mean, I did it, but it's not scanning the all TP's on satellite …
I have "factory preset" setting (IA5 97W) for universal LNB is 9750 (LNB) and 10600 (Signal). I'm assuming that's the LOF setting.
With this settings I don't see any TP or channel
09750-10600 is the L.O. value for a Universal LNBF (are you sure its a universal?), if you feel you are close to a satellite try a blind/TP. scan!
PSB,
The dish is pointing to the 97W for sure because I have Nexus PCI setup working no problem. (Currently the Nexus setup is away, so I can't look up the settings)
The LNB that I have on it is
FSS Digital KU LNBF
Freq. 11.7~12.2GHz
N/F - 0.6dB
This receiver was set to some channels on 97W that are no longer FTA, so when I do the rescan it goes thru the all transponders, but displays only ones I set before as a "favorite"
Last night I reset the receiver to the factory settings, and I'm basically setting up from beginning, after selecting all settings for 97W (IA5) and trying to scan all TP's it tells me "no signal was found"
No switch in my setup, RG6 strait from LNB to receiver
Ready to start!
IA6 Newbie Questions
